Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
LTE Yota (Yota One/Swift LU150/156/WLTUBA-107) - Ethernet over USB Asus - Page 2
Page 2 of 27 FirstFirst 123412 ... LastLast
Results 16 to 30 of 392
Thread: LTE Yota (Yota One/Swift LU150/156/WLTUBA-107) - Ethernet over USB Asus
    2. ethernet over usb , ( , , ). , . , .
    * Wiki *
    , cdc-acm. usbserial.
    LTE- ,
    /dev/ttyUSB0 : 1.1 : Manufacturer="GCT SEMICONDUCTOR Inc" : Product="Modem Yota"
    Arrow Yota One LU150 LTE
    Yota One LU150 LTE
    Yota
    4G 15 .
    http://ru-4g.livejournal.com/505236.html
    : 2,6
    : USB 2.0
    : Windows XP SP3/Vista/7, Mac OS X 10.5/10.6.
    Linux , CDC/RNDIS
    : 78×28,1×12,3
    : 27
    : GCT Semiconductor
    : Quanta Microsystems Inc, made in China
    USB- Quanta Computer Inc. (LU150, rev.01) GCT GDM7240.
    http://ru-4g.livejournal.com/456771.html
    LTE . USB- Yota,
    Quanta Group GCT. 2,9 . .
    Ethernet-,
    , USB- Ethernet-over-USB.
    , Wi-Fi-, Quanta Qualcomm.
    4,9 . . . WiMAX-,
    LTE- SIM-, , .
    http://www.moscow3g.ru/novosti/yota-...et-modemy.html
    Quote Originally Posted by Guanch View Post
    cdc-acm. usbserial. LTE- ,
    cat /proc/bus/usb/devices
    cat /proc/bus/usb/devpath
    /sys/bus/usb/devices/
    usb 2-1.2: new high-speed USB device number 27 using ehci_hcd
    usb 2-1.2: New USB device found, idVendor=1076, idProduct=8002
    usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    usb 2-1.2: Product: GCT UDC-RNDIS Subsystem
    usb 2-1.2: Manufacturer: GCT SEMICONDUCTOR Inc
    rndis_host 2-1.2:1.0: eth1: register 'rndis_host' at usb-0000:00:1d.0-1.2, RNDIS device, 00:09:
    Quote Originally Posted by UstasLancer View Post
    modules.tar.gz - : usbnet.ko cdc_ether.ko
    /opt/bin ( /opt - ,
    insmod /opt/bin/usbnet.ko
    insmod /opt/bin/cdc_ether.ko
    Jan  1 03:00:19 kernel: usb0: register 'cdc_ether' at usb-0000:00:04.1-2, CDC Ethernet Device, f2:87:f1:4a:e2:cf
    Jan  1 03:00:19 kernel: usbcore: registered new interface driver cdc_ether
    LTE- ,
    minicom AT-.
    * Wiki *
    Quote Originally Posted by Omega
    T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  9 Spd=480 MxCh= 0
    D:  Ver= 2.00 Cls=02(comm.) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
    P:  Vendor=1076 ProdID=8003 Rev= 1.00
    S:  Manufacturer=GCT SEMICONDUCTOR Inc
    S:  Product=Modem Yota
    C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=  0mA
    I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=06 Prot=00 Driver=(none)
    E:  Ad=81(I) Atr=03(Int.) MxPS=  64 Ivl=1ms
    I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=usbserial_generic
    E:  Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
    E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
    Device         : Location : Info
    /bin/sh: /sys/bus/usb/devices/: Permission denied
    minicom AT-.
    WAN, LAN, DHCP NAT. 10.0.0.1 - .
  6. Quote Originally Posted by Guanch View Post
    LTE- ,
    CDC/RNDIS.
    kernel.config
    mii=y
    rndis_host=m
    cdc_ether=m
    usbnet=m
    makefile usb
    $(SRCMODULESDIR)/drivers/net/usb/cdc_ether$(ko) \
    $(SRCMODULESDIR)/drivers/net/usb/rndis_host$(ko) \
    $(SRCMODULESDIR)/drivers/net/usb/usbnet$(ko) \
    insmod usbnet
    insmod cdc_ether
    insmod rndis_host
    Jan 1 04:00:04 kernel: usbcore: registered new interface driver cdc_ether
    Jan 1 04:00:04 kernel: usbcore: registered new interface driver rndis_host
    Feb 23 12:33:29 kernel: eth2: register 'rndis_host' at usb-0000:00:04.0-1, RNDIS device, 80:00:60:0f:e8:00
    WAN eth2 dualwan
    Quote Originally Posted by sorine View Post
    CDC/RNDIS...
    WL-500W (WL-500GP v.1 wi-fi 128 ).
  8. Quote Originally Posted by Guanch View Post
    , mii( ) - usbnet. . RTN?
    , WL500W-1.9.2.7-rtn-r3702.
  10. MIPSr1 3816 RTN
    insmod /opt/lib/modules/2.6.22.19/kernel/drivers/net/usb/cdc_ether.ko
    insmod /opt/lib/modules/2.6.22.19/kernel/drivers/net/usb/usbnet.ko
    insmod /opt/lib/modules/2.6.22.19/kernel/drivers/usb/core/usbcore.ko
    #lsmod
    cdc_ether 4096 0
    usbnet 16384 1 cdc_ether
    usbcore 106496 5 cdc_ether,usbnet,usb_storage,ehci_hcd
    usb0:
    ifconfig usb0 up
    usb0:
    usb0 Link encap:Ethernet HWaddr D6:C8:11:22:33:44
    RX packets:54 errors:0 dropped:0 overruns:0 frame:0
    collisions:0 txqueuelen:1000
    RX bytes:2052 (2.0 KiB) TX bytes:0 (0.0 B)
    br0 usb0:
    brctl addif br0 usb0
    USB ...
    http://www.dd-wrt.com/phpBB2/viewtopic.php?p=485840
    insmod usbnet
    insmod cdc_ether
    insmod rndis_host
    WAN eth2 dualwan
    post-firewall - :
    insmod /opt/bin/rndis_host.ko
    ifconfig rndis0 up
    udhcpc -i rndis0 -s /tmp/udhcpc
    iptables -I FORWARD -i br0 -o rndis0 -j ACCEPT
    iptables -t nat -A POSTROUTING -o rndis0 -j MASQUERADE
    http://www.dd-wrt.com/phpBB2/viewtopic.php?t=146117
    Asus RT-N16: Firmware Version: 3.0.0.3.94
    Jan 1 11:00:07 syslogd started: BusyBox v1.17.4
    Jan 1 11:00:07 kernel: klogd started: BusyBox v1.17.4 (2012-01-17 06:59:58 CST)
    Jan 1 11:00:07 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.4) #1 Tue Jan 17 07:12:50 CST 2012
    Jan 1 11:00:07 kernel: CPU revision is: 00019740
    Jan 1 11:00:08 kernel: Built_for__asus_n66u_2011-10-27
    Jan 1 11:00:08 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Jan 1 11:00:08 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
    Jan 1 11:00:08 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
    Jan 1 11:00:08 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
    Jan 1 11:00:08 kernel: ehci_hcd 0000:00:04.1: irq 5, io mem 0x18004000
    Jan 1 11:00:08 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
    Jan 1 11:00:08 kernel: usb usb1: configuration #1 chosen from 1 choice
    Jan 1 11:00:08 kernel: usbcore: registered new interface driver usblp
    Jan 1 11:00:08 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
    Jan 1 11:00:08 kernel: usb 1-2: new high speed USB device using ehci_hcd and address 2
    Jan 1 11:00:08 kernel: usb 1-2: configuration #1 chosen from 1 choice
    Jan 1 11:00:08 kernel: usb-storage: Quirks match for vid 152d pid 2329: 8020
    Jan 1 11:00:08 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jan 1 11:00:08 kernel: usbcore: registered new interface driver asix
    Jan 1 11:00:08 kernel: usbcore: registered new interface driver cdc_ether
    Jan 1 11:00:08 kernel: usbcore: registered new interface driver net1080
    Jan 1 11:00:08 kernel: usbcore: registered new interface driver rndis_host
    Jan 1 11:00:08 kernel: usbcore: registered new interface driver zaurus
    Jan 1 11:00:09 kernel: br0: starting userspace STP failed, starting kernel STP
    Jan 1 11:00:09 kernel: vlan1: dev_set_allmulti(master, 1)
    Jan 1 11:00:09 kernel: vlan1: dev_set_promiscuity(master, 1)
    Jan 1 11:00:09 kernel: device eth0 entered promiscuous mode
    Jan 1 11:00:09 kernel: device vlan1 entered promiscuous mode
    Jan 1 11:00:10 kernel: device eth1 entered promiscuous mode
    Jan 1 11:00:10 kernel: br0: topology change detected, propagating
    Jan 1 11:00:10 kernel: br0: port 2(eth1) entering forwarding state
    Jan 1 11:00:10 kernel: br0: port 1(vlan1) entering forwarding state
    Jan 1 11:00:10 stop_nat_rules: apply the redirect_rules!
    Lightbulb lte
    syslog .
    shared/Makefile -  CFLAGS	+= -g -DDEBUG
    rc/Makefile -  CFLAGS	+= -g -DDEBUG
    * Wiki *
    RT-N16-1.9.2.7-rtn-r3818.trx .
    * Wiki *
  1. LTE Yota Quanta (Quanta 1QDLZZZ0ST2/1K3) + Asus WL-500gP
    By gleb_antonov in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 11-10-2016, 18:30
  2. LTE 4G /MTC/Yota (Huawei E392/E398) Asus
    By vrungel in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 06-06-2014, 08:54
  3. WiMax Yota + Comstar (SWC-U200/BCS200) Asus
    By Frogy_f in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 25-05-2012, 10:13
  4. Asus + SWC-U200 = Yota Wimax
    By s-s-s in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 10-03-2012, 22:26
  5. DIR-320 + GPRS/3G/CDMA + Yota = ?
    By Komandir in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 28-12-2011, 16:25
